Hamster":3lwgi0my said:
Bumping this post again. I have 2 out of 3 of my Rule Automatic 1100 bilge pumps (Model 27SA) now failing the automatic function - not the manual.
I'm curious if Salish Seeker can tell the difference with the Rule Mate 1100. It appears to not do the automatic cycling, but instead sense whether water is in the bilge. Is this a better solution?
Having 2 of 3 pumps no longer function automatically after just over 2 years is not comforting. For those with this model, please make sure you check to see that all are actually cycling because if you leave your boat and the bilge fills up, the pumps might not activate.
Bilge pumps and Auto bilge pumps are one of the most important components installed in the boat. Yet the pumps seem to have a high fail rate. At least the automatic side of the pump does. If you put an electrical component in water it is going to fail! If you put a mechanical component in a bilge it's going to get fouled.
The mechanical float switches worked for years. But.... If the bilge was dirty the float would get stuck, pump would come on and run until it overheated and destroyed the pump motor.
Then the floats were installed in protected cages with micro switches. These seemed to work better as long as the boat owner kept a clean bilge. If not, oily Gunk, small pieces of debris, would build up in and outside of the cage and the float would get stuck on or the float would not operate freely and work erratically.
Electronic sensing switches were introduced using the water to be the conductor. Water level gets to the conductive sensors the pump turns on. No moving parts but electrical devise under water. Sealing the devise properly during manufacturing was an issue. The sensors that were built right worked great the sensors that didn't failed. I call that the manufacturing rule 10% failed and that 10% are there ones we heard about. The more common issue with these auto switches , dirty bilges caused a build up of gunk around the sensor, this interfered with the water making good continuity.
The load sensing switches were introduced. The load sensing are electronic, operate on a continuous on/off cycle, If operated in a dirty bilge, or small debris gets lodged in the cage, or not (sealed properly 10% rule) They will probably fail.
One additional cause of failure to all of the above float switches is electrical installation. In my years of repairing systems in boats. Bilge pump failures were a common issue. It was also a PIA. Many are installed in hard to get to places. Many times a failed bilge pump switch or pump was due to poor wiring. The connections were made low in the bilge instead of high in the compartment. The connection was not water tight. Eventually corrosion caused a poor high resistant connection, fuses would blow or the pump or switch would not work at all. Pumps and switches are replaced and seemed to resolve the issue but in reality the installation of new components required a new connection and that is really what fixed the issue.
The theme I am trying to make is Auto float switches fail, pumps fail, 10% rule. Most of the failures have to do with installation and maintenance.
*Keep the wire connections clean, dry and sealed.
*keep the bilge clean, oil free and debris free
*Inspect the bilge pump, clean debris around it. Know where the fuses are located . Know the proper fuse size based on what the pump manufacture states for the model. Not what was installed or someone tells you will work. Never install larger fuse unless it is required by the specifications of the pump.
* test the operation periodically not when you have a problem.
You may find the reliability to be better with preventative maintenance. Or you are unfortunate to be in the 10% Rule!
