SJI Sailor
- Nov 28, 2018
- Non-Fluid Motion Model
- American Tug (formerly had C30)
This is about the shaft seal nuts? Using two nuts there is standard. One serves as a lock nut to help ensure the other doesn't come loose.
To adjust, use two wrenches (there is another thread recommending some -- they have to fit together quite closely, which is a challenge with many generic wrenches). Hold the inner nut with one, then loosen the outer nut first, and finally adjust the inner one (along the lines of what Brian noted, small changes at a time, there is any travel left). When done, hold the inner one in place and (not too forcefully) tighten the outer one onto it to lock.
