Barnacle Buster versus CLR
bob daily
C-24 C SE
2129K809
Scuttlebutt
I usually pickle my heat exchanger in the boat every spring during my annual maintenance and de-wintering. I had purchased a gallon of Barnacle Buster as I do every year for this purpose.
The other day I was cleaning the shower heads in the house ( hunny doo’s ) and decided to soak one in the Barnacle Buster and the other in CLR, both were about the same amount of calcium buildup and soaked for the same amount of time.
To my surprise the CLR out performed and did a better job than the Barnacle Buster!
The Barnacle Buster was 4 times the cost of the CLR and did half the job.
Both have acid as the main ingredient, same environment impact and warnings.
Just another example of higher prices on a product if you label it for marine use!
Bob
What engine are you cleaning. And do you have a video of your process? Mine is a Vplvo 440, and I haven't done it yet.
I have a R-21 2009 model with a Yanmar 3YM-30 engine. Yearly I clean the raw water heat exchanger using a cleaner.
My procedure is to close the raw water inlet, I have a hose attachment between the raw water filter and water pump I attach a hose to, and place the other end in a gallon of the Barnacle Buster and run the engine until the antifreeze has discharged and cleaner is starting to come out of the exhaust at which point I shut down the engine and let it set overnight!
The next day I usually service the engine and run fresh water through it. This is what I call pickling, it’s basically the same procedure as winterizing with RV antifreeze.
Hope this helps explain. Bob
I've got a 2006 Nordic Tug 32+ that's up for sale (downsizing). I've had the tug for 21 years, and acid flush the Cummins 6BTA each Fall. I've done the Barnacle Buster circulating flush a couple of times, but since the boat has been in a fresh water slip the last 11 years, I'm just doing a quick, simple "pickle" flush before the Fall haul. I've been using "Acid Magic", a buffered muriatic acid with great results, primarily to keep the heat exchanger clean. You can get Acid Magic online, hardware stores, or where pool cleaning supplies are sold, usually around $20 a gallon. Don't forget to remove any engine anode(s) and plug the hole.
