Battery charger for RT 21 2011
amacmillan
C-24 C SE
FLMT2110G011
Tug - Along
I have a 2011 RT 21 and need a replacement battery charger.
What would you suggest for this.
Ansell MacMillan
Ask RT Factory parts Dept for this would be my advice.
There are a wide variety of shore power chargers available. They are usually sized for the size of the battery bank(s). Some are single circuit (starting battery), some are multi circuit (starting and house bank are charged separately) . If you have 200Ah of battery, then a 20A charger is sufficient for flooded batteries.
For AGM batteries you can size up the charger as they will accept a higher charge rate without damage. If you have AGM batteries, ensure the charger has an adjustable output voltage to match the specs of the battery manufacturer.
I've always been partial to the Xantrex True Charge2 series.
Sent from my SM-T700 using Tapatalk
