portlandtug25
- Jun 17, 2014
- C-26
- Regalo
Hello All,
Some electrical advice would be appreciated.
Trying to decide if it's time to replace the factory AGM batteries In my R25 SC. It was delivered in June 2014 and has just under 300 hours. Only accessories driven by house batteries are the 12v refrigerator and rarely the Espar furnace and of course cabin lights. It's always plugged in to shore power in the slip and rarely do i go more than 2 days without shore power when cruising. Also have a solar panel from factory. On my last outing, after one day without shore power, I didn't have enough house battery to ignite the Espar heater the next morning. The refer was set at its lowest setting and it was not hot outside.. It was sunny the day before so I assume i was getting a little help from the solar panel.
So here are my questions:
1. Is 5 years a typical life span for the factory AGM batteries?
2. If I replace the house batteries (I think there are two of them), should I replace the starting and thruster batteries at the same time? Never any problems starting the engine and I use thrusters very sparingly.
3. How can I tell which batteries are which without disconnecting them?
4. If I replace any or all, what's the best replacement type? I like not having to check water levels , but maybe the AGM don't have the lifespan of a flooded.
Electricity is not my forte!
