LAKERtoo
- Sep 13, 2014
- C-24 C (Sterndrive)
- FMLR2130J405
- RIBBIT
.. I picked up a Noco Genius G1100 Battery Charger/Tender to hook up to the 2 batteries in my R21 Classic for the winter .. the batteries are hooked up in the common configuration where the switch can set them to OFF/ONE/BOTH. When they are set up like this, my assumption is that I connect one of the ring connectors to the negative post on one battery and the other to the positive on the second .. so 1) does it matter which battery I put the negative connection on and 2) .. what position should I leave the battery switch ? off, or both ?? Thanks for any input ..Rob
