Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
Hi
I recently bought a cutwater 28 (2012) from the dealer here in PNW and I am having trouble with the engine battery. It was weak to start when I picked up the boat from the dealer and today when starting it failed to start. boat started fine when batteries were crossovered.
so I did a little multimeter digging...
After I started the first time with all batteries, the second time i managed to successfully start (just caught) with just engine battery - but it wasn't exactly confidence inspiring! therefore I decided to retry a start with just the engine battery with the multimeter measuring min/max voltages to see if the battery is toast.
With the engine off and shorepower unplugged. engine battery is showing 12.83volts.
using the min/max feature. cranking the engine, the battery volts drop to 9.99V and once the engine battery charger kicks in after start, the voltage increases to 14.27v
when the engine is off and back on shore power the DC panel shows 14.75v showing the shorepower charger looks to be charging ok. I don't appear to have any fuses blow on the cables (I forgot to check the voltage on the actual battery when on shorepower (that shorepower plug really stops that battery hatch from opening easily 🙂)
This is a universal AGM battery. 3 years old.
Is the battery screwed or is it something else? what else can I do to narrow down the issue?
ideas appreciated!!
Gavin
ideas appreciated!!
Gavin
