JerryE":3146akdf said:
I wonder if anyone has a chart of average oil pressure levels at different speeds (under load) starting at idle (750 rpm-no load of course...........
.............Guess I'll have to rig a manual gauge for that–does anyone know if there is a spot(s) for that on the engine and what gauge to use?
Two things come to mind. First, your oil pressure shouldn't change with engine load. It changes with engine speed as the oil pump rotates faster and faster until it either reaches the maximum that the pump can deliver, or a relief valve opens.
It also changes with viscosity, and you'll see a higher pressure on starting a cold engine than you will when the oil is up to working temperature. Even the magic of multi-grade oils doesn't change that.
Adding a mechanical gauge is an excellent idea, and easily achieved. Although you can get a $10 gauge from an auto parts store, I'd recommend a better quality VDO unit, as used in aviation and German sports cars.
http://www.aircraftspruce.com/catalog/inpages/vdopressureoil.php
Installation would be simplest by installing a brass ' T ' in the existing oil pressure switch port, then connecting both the existing OPS and the feed to the mechanical gauge to the ' T '.
If it were me, I'd install the new gauge in the engine compartment, rather than snake a pressurized oil line all the way through the boat to the helm.
That way you can compare the mechanical gauge reading to the digital one at the helm (with the aid of a crew member) and not risk spraying the cabin interior with hot oil should something unfortunate happen!
Lastly, should an obstruction make the installation at the OPS location difficult, you could have a short hydraulic hose made up at NAPA or a similar store to bring to connection point for the ' T ' out to a more convenient location.
However, if you do that, make sure to run a ground connection to the ' T ' or you won't get an input to the digital gauge.
