Bilge pump, 2014 21 ec
Stewartn
C-24 C (Sterndrive)
Splashed yesterday. This morning did my routine system ck and No Bilge Pump. Bilge was full but auto switch did not turn on. Tried manual pump switch. No joy.
Where do I look first, then second? Also , any recommendations for replacement parts appreciated.
Thx all
Stewart Napoleon
2014 21 ec
Leslie Ann
Greenwich CT
Hello Stewart,
Have you checked the voltage to the battery yet? have you checked the fuses to the high-water alarm? this will be located just above the batteries. what I would also check is the connections right at the alarm switch and at the bilge pump. make sure you have correct voltage showing and no corrosion.
Thank you,
