PicoGoss
- Oct 10, 2013
- C-28
- FMLT25171910
- Nano
I have installed a bilge pump cycle counter on my RT 27. I mounted it in the pilot area next to the heater control switch. I captured to 12V positive and negative power from the three way battery voltage gauge terminals. My reasoning was that the counter should draw very little power. I connected the activation wire to the manual bilge number one breaker reasoning that this terminal would only be energized when the bilge pump was activated. I tested it using a flow of water into the bilge. So far so good. Now I find that my counter seems to remain at 0 while I’m under way, but shows suspiciously large numbers (currently 23) after a night at the dock. Maybe my set up logic is faulty, but if not, it would appear that the circuit from the manual breaker to the pump is being energized by some other source. If fact, there were two existing wires on that manual breaker terminal. The simple question is; where does the second wire go and to what purpose?
