Bilge Pump Questions
aculverwell
C-302 SC
USFMLT3133
Red Sky
Hi folks, two bilge pump related questions for the brain trust:
1) I spent part of last weekend replacing bilge pump #1 (the one underneath the shaft) on my R31 because it had broken completely loose and was no longer attached to the hull. All 3 of the plastic footing tabs that are used to screw the pump down had broken off-- in addition both plastic tabs that can be used to screw down the electronic sensor had also broken off. (Editorial opinion... Johnson Pumps should use a better grade of plastic in these areas of the pump). I was surprised that the pump could have broken loose since as far as I know nothing has banged into the pump and it is in a very protected area (and consequently very hard to replace!). So Question #1-- is this a common problem? Anyone else have a similar issue?
2) Bilge pump #2 (the one furthest forward in the engine compartment) appears to have two different sensors attached to it. (Bilge pump #1 only has a single sensor). Question #2-- does anyone know the reason that there would be 2 sensors on this pump? Perhaps one is electronic and the other a float switch?
Thanks!
I believe the second switch is the sensor for the high level alarm.
I had same thing, pump under shaft tabs broke. Second sensor on fwd one is high water.
Thanks! Good to know that the 2nd sensor is the high water alarm. I was wondering where that was...
Just fixed the same #1 pump on our 25sc. Both the sensor and the pump were broken same as yours. My solution was to drain out, clean, and dry the bilge. We then used 3M marine adhesive to the base of the pump/bilge as well as on the sensor and side of the pump. Very tight place to fix but it is now solidly in place and working fine. Good luck if you have big hands and don't enjoy laying down into the bilge area for a few minutes.
I also have an R31 and yes I had the same problem. A bear to get to hanging upside down off the back of the engine. Mine is marginally in there. I think there are 2 screws holding the pump in.
Has anyone else had a problem that the bilge pump under the stuffing box will not pump water. What I have found is it appears that the one way valve on the starboard stringer seems to dry out and stick in the closed position and prevent water from getting past it. This sort of defeats the purpose of the bilge pump. My latest attempt at a fix is to put a little grease on the flapper valve to hopefully prevent it for sticking shut.
Any other suggestions?
John
Tug Travelers
Guided Flotilla Cruises
This happened to me just yesterday. The pump ran and ran but nothing came out. A little air pressure applied to the bilge pump thru hole on the side of the boat and it starts a pumping! You can even do this with your mouth! Don’t ask me how I know. 😉
You might try a 5 gallon bucket of warm soapy water poured in the Bilge carefully to avoid getting water where it is not supposed to go. That seems to work on my boat. I do it once or twice a year.
The bilge pumps and sensors require periodic maintenance. You should remove the pump cartridge and make sure there is no accumulation of debris restricting the impeller. The sensor should be cleaned with simple green of similar product to remove any oily film. The check valve, maybe once a year, should be disassembled and checked for integrity.
I had my stern bulge apart yesterday. I found hair and plastic wrapped around the little impeller. This had caused the pump to not work properly and would not work. Because of that it’s dedicated spade fuse blew and the only way the pump worked was with the dash on/off switch....which dies help if a problem develops when you’re not on the boat. Moral of the story is clean n inspect on a regular basis. I’ve not had any trouble with a bulge pump breaking loose but good to know what to look out for.
Jim
To add to bilge pump issues, this was the first week I had Tingira in the water so except for sea trials, she has not been used. During this brief time, I have had the following issues:
1. Aft Bilge Pump - Would not turn on in the automatic mode. Spoke to Ivan Guzman of Ranger Tugs who diagnosed the problem as incorrect fuse size (7.5 AMP vs the 5 AMP installed). Switched the fuses and problem solved.
2. Aft Bilge Pump (Again) - Within hours, it periodically sounds like a loud seagull cry. I know the pump is clean as I pulled it out and inspected. Doesn't make the sound in the manual mode.
3. Shower Sump Pump - Came in the morning and found it on. Suspect it had been on all night as the batteries were low and pump very hot. After inspecting, it continued and I had to pull the fuse. The shower was never used.
I have contacted my Dealer and Ranger Tugs regarding resolution as this equipment should not be failing with such limited use.
Boss Mate: I had the same issue on our R29S with the shower sump. First try taking the top of the sump off and cleaning the pan, float, etc. if that does not work get ahold of the Rule Company to explain the problem. I did this and was sent a new float to install and it all seems to work fine over the last 3 months. Also check all of the shrink wrap connections on the sump pump itself to make sure there are no loose connections.
Keep us posted.
Jim
Yep, somebody might have put in the wrong fuze or it came with the wrong one or it came with the right one and the one in now is wrong, which are all strong possibilities in this wide wide world of boating. If you follow Ronalds teachings and need to trust but verify check the amperage draw spec on the pump and ensure it’s currently fused to 1.5 times that which is standard. Most likely the advice from RT is spot on.
Here something moving is rubbing against something that doesn't. This is actually a very fortunate turn of events as it will cure itself when the moving part wears down, one of the rare rare times a boat “self repairs” so count yourself lucky. Different bird species noises will appear as this takes place so you’ll know when success is on its way.
Sump pumps are troublesome, look up “sump pump” in the ‘Nuts for more on this. Many folks just keep this fuse out unless showering, I do.
Keep in the forefront of your mind none of these are equipment “failures” No No; the bar for declaring failure in boating is far far higher than this. This is just equipment “breaking in, getting to know each other, acquainting you with this thing called boating, trying your patience, helping you fall off the wagon, testing your DIY skills, raising your blood pressure, getting the look, finding out if boating is really for you” etc. etc.
Failure is that shower pump burning your boat to the waterline; failure is that bilge pump letting her slip below the surface, these are failures.
So gentle boater take heart, you’ve begun your boating journey and if she’s afloat and not aflame, available and ready for you and yours to step aboard and begin that days adventures then you’re what’s known in boating as “shipshape” and don’t forget to hold yourself ready to fix whatever comes up next and it and more will on this you have my personal guarantee!
And in all sincerity, this is where Ranger really really shines, service after the sale, as you’ve already found.
We had 18 hrs on our 2018 27OB and had the shower sump pump come on when I turned the battery switch on. Shower has never been used, pulled fuse, dealer replaced pump next time boat was at the shop. These cheap junk pumps are failing too often!!
I for one think the float setup in the shower is a problem, especially on some of the vessels that use the same sump for the air conditioner condensate. On my 27 as many other models the sump is used only for the shower. I rewired mine to turn on when needed with a spring loaded switch. There have been too many occasions when that float sticks. I suspect it is a function of crud from the shower and/or excessive jostling when towing over the road.
FYI - I contacted Rule today and they are replacing the pump and float switch. All I had to do was provide documentation that I own the boat. Easy enough.
Thanks for the assist!!!
I have thought about buying a teeter hang (inversion therapy) to work in the engine well
All this good talk about the shower sump triggered me to ponder how I think of and treat the various 12 volt pumps in my life.
I think of the bilge pump as a garbage disposal, everything that ever got loose in any vessel ended up in it’s area. Using the upside down dog position I pull it whenever I think of doing so, even if it’s working well and have never not found nothing in it, usually wrapped pretty tight to the impeller.
On new to me boats and annually thereafter I pull the bilge pump and plug, flush water up into the hull as best I can and drain said water through a colander don't tell the wife. Mostly I find construction debris which here on the ‘Nuts is acknowledged to plug those rear weep holes submerging thrusters. Butt connectors, tube fuses, light bulb ends you name it I’ve found it. The most worrisome things I’ve found are the screw portion of clamps which means somewhere there’s a clamp that only appears to be holding tension.
I figure the shower pumps are problematic due to what they have to pump and are left sitting in as some fluid remains in the sump. Not wanting to take it apart as it ain't broken which in boating only means it worked the last time needed, on my new to me boat I poured hot water into the sump and captured the water it pumped overboard in a clear glass one gallon pickled egg jar, this being a jar I once won a pickled egg eating contest with so the jar has some sentimental value to me.
I then refrigerated said jar to see what would stratify and stratify it did. There was a pretty good layer on the surface composed of soap scum, (sorry) hair, bobby pin ends and that’s as close as I looked and now the stream seems thicker and fuller hopefully indicating more efficient operation.
So I guess the takeaway here is you need to stay on top of all pumps, treat them well, carry spares. Do the same to the one way valves but that’s another story.
