H28
- Dec 27, 2014
- C-30 S
- Hygge
I was under the impression that each bilge pump was wired thusly: directly to the battery via the float switch and to the panel for the ability to manually turn on the bilge pumps. Neither of my bilge pump were turned on at the panel and I came to the boat and the high water alarm had gone off. Neither bilge pump activated automatically. Water just above the prop shaft. When I flipped them on at the panel both activated.
The one toward the bow stayed on even when the water went below it's float switch. The one toward the Stern shut off when the water went below its float switch.
That doesn't seem correct to me. What am I missing?
