PuffinStuff
- Feb 9, 2014
- C-288 C
- Puffin
Hello Tugnuts!
We have a 2012 R-29 and recently I found a couple of electronic glitches that I could use some help with. The first was the autopilot showing "Searching for Autopilot Controller". I couldn't engage it no matter what, but with a quick tip from Andrew at Ranger, I unplugged it and did a "hard reset" which worked great.
My great luck, now we have another issue. The depth will lock on for a while, but then begin blinking - even in the marina or dead calm water at slow speeds. This hasn't happened before, so tried the same "hard reset" by unplugging power at the Garmin GSD 22. Also unplugged and reconnected the power (and NEMA 2000), but did not get the same quick fix here.
I have heard the software may need to be updated from Garmin. We have a 5215 chart plotter. Could it also be the transducer is mucked up? Do I need to get under the boat? How is this unit fitted to the hull of the boat on these models?
Any help is much appreciated.
Paul
PuffinStuff
Paul
PuffinStuff
