Blue sink drain gasket
dbsea
HALCYON
The head bowl sink on my c30-cb is missing the gasket on the drain, so the water runs right out. Anyone know where to get the gasket?
These worked on the blue sink in my 2015 28 Cutwater. I found them on Amazon.
5Pcs Sink Plug O-Ring Spare Sealing Gaskets for Metal Basin Plugs and Pop up Bath Sink Basin Plug Inner Diameter 31.5mm Outer Diameter 38mm Silica Gel Black
https://a.co/d/2leHJRo
I am not sure if plumbers putty will work on a pop-up drain. The gaskets were very reasonable, 5 for $6 or $7 . Just unscrew the pop-up drain and feed the gasket on then screw the pop-up back into place. One gasket will last approximately 3 years, not bad for the price.
Excellent, thanks!
