Irish Mist
- Apr 25, 2012
- Orillia Ontario
- R-29 Classic
- FMLT2922K011
- Irish Mist
Been getting info from the Fusion factory and thought I would share this part of an email :
None of the Fusion head units is built in a Bluetooth capabilities, in Jun 2013 we will receive an accessory device (dongle cable).
The MS-BT200 is a device (Dongle Cable) to connect thru the Sat Radio connection of the head unit and the you can stream the audio via Bluetooth they can do the Back track, forward track and pause, it will shows the information from the music in the display of the head unit, we will get an update software for the 700 series head units for these features.
The MS-BT100 is a device to connect thru the Aux input of the head unit and the customers can stream the audio via Bluetooth they can do the Back track, forward
track and pause, the customers can see information from the music on the cell phones. (This device is the only option for the MS-XX600 series head units but it can work with the MS-XX700 series head units)
If you have in mind to add Sirius XM tuner you will need to use need the MS-BT100 thru Aux input.
