trawlerdeejay
- Jul 9, 2015
- C-28
- FMLT2723K112
- Hail Mary
I have a 2012 Ranger 27 (The Beach House) When using the bow thruster the other day, it remained "on" even though the joystick was in the neutral position. Jiggling the control would not turn it off: the off button would not turn it off. finally, used Thruster switch on the battery bank to turn unit off. Waited a day- and turned baatery switch back on- thruster began to run again. Turned battery switch off.
In order to ascertain if the toggle switch at the helm was bad, removed toggle switch and switched wire connectors with the stern thruster - and turned on battery switch. Bow thruster came on immediately and "off" button had no effect.
I believe that the solenoid is bad. Tried to look at, and possibly tap the solenoid, but it is buried under the A/C unit and difficult to get at.
Your thoughts?
trawlerdeejay
Your thoughts?
trawlerdeejay
