SilverSailor
- Mar 2, 2016
- C-24 C
- Non-Fluid Motion Model
- Beneteau Oceanis 321
- Aleta Jewel
This is one for the factory folks or a knowledgeable RTer. I have a 2015 R31-S and the cabin overhead lights are great, but there are times they are too bright. While installing a dimmer for these cabin overhead lights it was necessary to remove the 12VDC breaker panel. While it was open I noticed that all of the labels for the 12VDC breakers were wired in a daisy chain fashion, both the 12VDC side and ground. It looked like all the wiring was already in place to illuminate these labels. There is even a gray wire with a red marker, if memory serves me??, that looks like it should feed this daisy chain 12VDC, but I can't trace it to it's source. I did jumper the daisy chain 12 volt connection to 12 volts and sure enough all breaker labels illuminated. So... my question is: where does this daisy chain 12VDC feed from - where does the gray with red wire originate?? I've tried everything I can think of. I'm planning on using one of the spare breakers to operate the illumination of these labels.
