broken search light connector
Mikep
R-31 S
Dive In
Searchlight not working so went looking for issue. On the male side of the 4 wire connector that screws into the flush mount connector below the arch, the yellow wire has pulled out of the connector.
Is this a Jabsco part or is this something that Ranger Tug installed. What I need is a new male plug with some wire attached so that I can splice the new one in.
Any help is appreciated.
I am pretty sure the wires can be inserted and are held in place with a small set screw. Did you try dismantling the end or did you and it is corroded and beyond repair?
knotflying":j3rmc2t1 said:
I am pretty sure the wires can be inserted and are held in place with a small set screw.....
They can be. On my boat when a wire became detached in that connector, I found that the strain relief grommet was shot. It may have been the reason the wire pulled out.
To make a repair of a pulled out wire, the connector has to be disassembled so I decided to just replace it which gave me a new strain relief grommet.
thanks for the insight on the replacement connector. I think that is the best bet to replace
