C-288 ground bus bar
JunieBird
Cape Carteret, NC
C-288 C
FML28C06C222
Boston Whaler SS16
Junie Bird
Hi,
Is there a ground bus bar behind the helm on the C-288? The load centers are well labeled but I cannot locate the common neg/ground. The USB port on the dash is missing a negative lead.
Thank you
Hi there,
There is a major ground bus on the electrical cabinet door in the head. It is in the center of the door with all the yellow cables. Are you sure it is missing the ground lead? It should be yellow. Hope this helps.
Cheers,
Ralf
Thank you, threw me off as there is a bright red terminal protector over the main lead cable. I did not have my circuit protector handy- 🙂
Yes, the USB plug on the dash has two male connectors... the one has a red + lead... the other has no wire
