dbsea
- Oct 1, 2021
- R-23 (Outboard)
- HALCYON
I’m really on a streak here - only 48 hours into this boat and I have a lot of questions!
I took the boat out for a spin on Lake WA this afternoon/evening, and upon return I shut everything down as normal. I noticed the aft bilge switch light was on, and thought maybe I hit the toggle accidentally when figuring out where the wiper switch was. Nope. Went back and opened the engine compartment and the pump was running. Didn’t appear to be much water in there, and it was gurgling as if it was running out of water to pump. It ran for probably two minutes, then turned off. Is it normal for it to run after you use the boat? Is this something to do with the drip of the stuffing box? Something else? I’m a rookie with direct drive, my last boat had I/o’s. Wondering how much to panic? <gulp>
