C-30 Prop install
tbadham
C-30 S
I had my prop removed by the boat yard and took it in for repair. Boat yard is having trouble re-installing. Apparently, they are unable to tighten the nut enough and are concerned the spacer is loose on the shaft. I purchased the boat used (It's a 2016) so do not know if prop hardware is all original. Anyone know how thick the space is supposed to be?
