B botelerr New member Joined Jun 9, 2021 Messages 3 Fluid Motion Model C-32 C Vessel Name Perseverance Oct 9, 2023 #1 I believe I need to reset the GFI on my inverter. Is the inverter behind the power panel ? Or is there another way to reset GFI? 2021 24 coupe. Thsnks
C CruisingElvinRay Well-known member Joined Nov 28, 2020 Messages 572 Fluid Motion Model C-242 C Vessel Name ElvinRay Oct 9, 2023 #2 botelerr":5qhwhmjh said: I believe I need to reset the GFI on my inverter. Is the inverter behind the power panel ? Or is there another way to reset GFI? 2021 24 coupe. Thsnks Click to expand... You should be able to get access to the outlet if you remove the battery switch cluster. You will see the outlets to port behind that panel. Sent from my iPhone using Tapatalk
