Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
Hi I have purchased a balmar smartgauge that I am trying to install.
my ideal location is above the battery switches as there is a spot free.
I have a few questions
1. how does this panel remove? There is a panel underneath that is screwed underneath but I dont see mounting screws for the panel that has the switches (solar, inverter, battery's etc). these panels are normally hinged on sailboats.
2. is there a recommended wiring run route from the battery box to the panel area? should I go underneath the icebox or and then under the oven (sounds like a nightmare) or instead hop over into the engine bay and route around the engine bay at the bow end of the engine and into the panel from that side?
If I cant get it to fit by the battery switches my other option is the helm area. Is the main forward/aft wire run behind the head board or in the conduit by the ceiling in the second cave berth?
any tips from others who have done the install?
thanks very much!!
thanks very much!!
