BB marine
- Feb 1, 2016
- R-21
- Non-Fluid Motion Model
- Mainship 34 Pilot
- PORT-A-GEE
After two boating seasons managing my fuel consumption with the Garmin and also recording all fill amounts in my Log book. I have always been disappointed with the Volvo EVC fuel gauge because it was so inaccurate. This winter I have done some additions to my fuel capacities and while doing them I completely drained my fuel tank. When I drained it My Garmin was showing I had 31.5 gallons left. My Volvo EVC was showing I had 57 gallons left. I knew the Volvo was wrong and that the Garmin was right. After 2 years of resetting the Garmin when refueling and entering fuel amount. It was off by 13.5 gallons I pulled 45 gallons out of the tank. Tank was dry! I contacted Andrew and asked if he could send me a tank drawing. He did! From the drawing I was able to calculate the volume of each inch of the tank. The first 3 inches of the tank the volume is less then the top 7 inches. Also from the drawing I was able to locate the manufacturer of the sending unit, WEMA. I spoke with technician at WEMA now called KUS. The technician gave me the part number of the sending unit. I ordered a sending unit ( now my spare sending unit or remote.) With it I was able to find all the resistance readings and mark their locations for calibrating the tank.
This pictures shows the remote sending unit which is attached to the EVC for calibrations. My VOA is attached to the tank sending unit reading the resistance of 106.3 ohms, which is equal to 41.5 gallons and 37 gallons are usable because the fuel tank pick up is 1 inch off the bottom of the tank and the sending unit is 1 inch off the bottom of the tank. My Calculations for first inch of fuel is 4.50 gallons( rounded). Looking at the markings on the remote sender I determined 119.4 ohms would be 32 gallons or 40%.
I confirmed tank volume setting is correct 80 gallons
I now went to multi point calibrations
First setting is 16 gallons of 20% = 144.3 ohms
second setting is 32 gallons 40% = 119.4 ohms
third setting is 48 gallons 60% = 80.4 ohms
forth setting is 64 gallons 80% = 49.4 ohms
fifth setting is 80 gallons 100 % = 33.4 ohms
Set empty tank
Set 10% alarm
I rewired the EVC harness to the fuel tank and checked results. 41.5 gallons 37 gallons usable . To check accuracy at another level I transferred 20 gallons of fuel main tank to my transfer tank. The main tank EVC gauge reading 16 gallons (1 gallon off) and the needle was just under a 1/4.
80 gallon fuel tanks used by Ranger/ Cutwater (25 tug and 26 Cutwater use this tank, the drawing was for an R25 but the tanks model number matched my tank FO8018) with 10" depth will have accurate reading using the ohm settings I recorded and I believe the 100 gallon tanks would be accurate too if they are 10" tanks. I have alligator clips on my remote sender now. It would take me 5 minutes now to calibrate 80 gallon tank.I will still continue to use my Garmin for a fuel gauge also.
Set empty tank
Set 10% alarm
