Chart lights
rckhorwitz
C-32 C
Scherzo
I have a Cutwater 24 and noticed that the middle, red "chart light" is out. While I seldom (never) use them, I still want to replace it. Do you know where I can get a replacement light and how to replace it? Does it simply pop out if pried hard enough?
try marinebeam.com
I had one not working also. I used a flat plastic pry tool to pop it out. Be very careful as there are spring clips holding it in. Once I got it l lowered down from the ceiling, I inspected the wires and noticed one of the wires was loose. I secured it and now it works fine. Hope this helps.
They are quite difficult to remove. As best I can recall (some years ago) when changing to all LEDs the brass bezel needs to be slightly rotated and then access is gained.
