Chimney
daveabramoff
C-248 C
What is the best way to reattach the chimney and mast support piece? I removed to replace wiring and the side mounting screw holes are deteriorated.
Hello,
Could you please send me some pictures of what you have going on so I might be able to help you? My email is kevinlamont@rangertugs.com please be sure to take photos so I can see up close and little back from that.
Kevin Lamont
Howdy Kevin, Thanks for your reply. Unfortunately, by the time I realized you had replied, I had already repaired the piece and forgotten to take photos. I wont make that mistake again. The lower side of the panel looked like a pincushion. There were about 12-16 holes where they had attempted to screw it to the raised section of the roof. Each one had blown out and broken apart and then they tried another spot with the same result. I sanded and repaired the broken sides with couple layers of fiberglas and when i repaint and refasten, I'd like to do it so it wont fail so miserably again. Thanks again, Dave
