hulla":2jl8f5tp said:Does anyone know where to fuse is for the cockpit fridge? Our fridge under the helm seat works fine while the one in the cockpit does not. I thought that the fuse would be the pace to start.
kevin_summit":1f904sn1 said:Hello,
Do you have the switch on for the cockpit fridge? It should be the port bottom "accessory" switch at the aft switch panel in the 1/4 berth entry. Hopefully this helps.
Kevin Lamont
kevin_summit":23ykrq6m said:Hello,
Kevin Lamont
what was problem with fridge? im seeing same problem
