DBBRanger
- Mar 31, 2013
- R-25 Classic
- Still Crazy
Many tugnutters have noted that they have combined their 2 house batteries and their thruster battery in order to get more house capacity. I have done this by adding a battery combiner switch so that I can easily "uncombine" them if desired. So I put in a battery switch with inputs of thruster battery (from thruster bus bar) and the other input from the house battery (from house buss bar). The output goes to the thrusters. The switch is usually in the "Both" setting, thereby combining house and thruster batteries that supply the thrusters but more importantly supply the house needs as well. If desired, I could also supply the thrusters with either the thruster battery OR the house batteries. See the schematic below.
I came back from a 3 month trip and added water to the batteries. The two house batteries took a substantial amount of water, the thruster battery took almost nothing and the starter battery needed no water. That seems to tell me that the thruster battery was not used much and therefore did not get charged much. When I use my multimeter to check current going through each battery, the total current is shared by the three batteries as it should be as well as the charging current is the same for each of the three. Also, my Victron battery monitor (using the shunt shown in the diagram) could be read in a way that also says I'm not using the thruster battery since it can show 75% SOC but the voltage is 12.3 volts when resting. It seems the voltage should be higher to match a 75% capacity when using three batteries.
So the question is why am I losing water in the house batteries but not the thruster? Any ideas?
