Diatom
- Nov 21, 2020
- R-21
- FMLC2613A111
- Misty Blue
Two issues with old Garmin 5212 / GHP 10:
1. Path oscillation (16 degrees peak-to-peak) on Autopilot. Issue resolved by recalibrating Autopilot unit.
2. Persistent 8 degree heading error on both GPS screen & radar screen. NOT cured by recalibration. "Whatever is directly in my path shows up at 11:59 on the screen where it should be at 12:00 - as if display imagery is rotated 8 degrees counterclockwise".
Crawl down to the dungeon to check the fluxgate: it's mounted on behind the helm heel-kick panel, at top. Mount is secure, does not freely rotate. No stray metal objects beyond cladding screws; wire bundles are 10" away along hull but at similar elevation.
Check readings dockside:
AP reads 323T / 307M
GPS (Garmin screen) reports heading 343M (does this even have meaning at rest? Not sure).
Physical compass atop helm reads 296 (obviously M)
Freshly-calibrated iPhone 14 reads 307M
Anyone see what's going on? Is a persistent 8 degree to port reporting error within tolerance?
/tmm
/tmm
