Andrew -
The good news is that I didn't need a new thru-hull. It is in fine shape.
The bad news is that the thru-hull/strainer was installed off center (shown by the picture) and with very little sealant per the mechanic that removed it. I now have several feet of wet hull core and a de-laminating hull. From the picture you can see that the water is clearly coming out of the side that has poor clearance.
I am now faced with some very serious fiberglass work since a moisture meter reveals that there is heavy invasion of water extending at least 2 feet forward and aft ... maybe more, but the curvature in the hull makes it impossible for the meter to get a reading. I am trying to determine how bad and where else the water damage is, but without knowing how the hull and liner fit together, do I have to rip up the whole hull?
Hopefully the factory can provide some guidance on the construction specifically, where the hull meets the liner to determine the likely areas of water damage to help with the upcoming extensive fiberglass work.
See water coming from upper left in a continuous stream
See how the thru hull was mounted off center in an oversized hole
- water stream above is coming from where their is too much margin
Here you can see the resulting de-lamination
I look forward to Rangers Tugs support.
- Eric
- Eric
