Coolant Flushing
danester
R-21
SEASCAPES
What is the capacity for a 2016 D3 220 coolant system? Can you please advise how much coolant I should expect to use / or how much I should have on-hand prior to flushing? Thanks
I just did mine this winter. A complete flush of engine, hot water and bus heater. I purchased 2 gallons of coolant. I did a true flush of the Hot water and bus heater and filled that system separately using the shut off valves and a pump then filled the engine coolant system. I did this during the winter and I assume most of the air has bleed out of the system simply by time. I now need to add about 1/2 quart of coolant. I would purchase 3 gallons to be on the safe side. It's good to have extra coolant on board to top off or because of a small leak.
