Coolant warning
markzorad
R-23 (Sterndrive)
Greyhawk
Have a new 2021 C30-S with D6-440 and keep getting coolant level warning.
Checked and level in tank is correct and can see no leaks anywhere.
Is there a reservoir with a sensor? If so where is it located? I couldn't see anything obvious.
Thinking maybe reservoir is low?
I have the same boat, just got it early August and had the same problem. Boat delivery captain told me the sensor is very sensitive. If you take the cap off it will look full. Had to add small amounts of coolant and then ran the boat, this happened twice and then the issue stopped. He also said by running the boat will eliminate any bubbles which also might cause issue.
OK I will try adding a little.
Thanks for the info!
That worked.
Thanks for the tip Gvellia!
