CaspersCruiser
- May 11, 2016
- R-27 Classic
- FMLT2709G112
- Cookie
I’ve had my 2012 R27 almost a year. I’ve discovered what I can only describe as a manufacturing error. Please don’t take this as a jab at Fluid Motion. On a few occasions, I’ve contacted them with questions about my used boat that was not purchased from them and they’ve always been accessible, responsive and a pleasure to deal with in every way.
I haven’t discussed this particular issue with Fluid Motion because there’s really nothing they can do about it. I am posting this as a heads-up for folks with boats of my vintage that may experience failed electrical equipment.
First a little background. Under the stern cockpit seat, I replaced the wooden platform on which the propane locker rested because a failed adhesive bond had allowed it to drop onto the holding tank. In the process of that modification I encountered wires to the propane locker solenoid valve that were incompletely butt-spliced.
The butt splices were good quality with heat shrink insulators, but the insulators on only one side of the butt splices had the heat shrink activated. The insulators on the other side of the butt splices were left completely open. That allowed corrosion to develop on the wires at the crimp joint on the open side. The wires had not yet broken, but they weren’t far from it. I cut out the old butt splices and installed new ones and heat shrunk both ends.
This wasn’t the first time I’ve dealt with this problem. My boat was delivered last April with an inoperative washdown pump. In the troubleshooting process, I found one of the failure points was a wire that had corroded and broken at an open insulator of a heat shrink butt splice.
What appears to be in play here is that during the manufacturing process, wire bundles are pre-made and installed with butt splices open on one end to facilitate later installation of electrical equipment. Then further in the manufacturing process, as electrical equipment is installed, the wiring for it is crimped into the open butt splices in the pre-made wire bundles, but the insulators are not heat shrunk. Hopefully this lapse in manufacturing process has been corrected in later boats, but I feel fairly certain there are other wires in this condition on my boat. It’s just a matter of time before they corrode and break. I’m going to try to hunt them down and repair them before they do.
Bottom line: If you experience failed electrical equipment in and around the stern cockpit seat area, start your troubleshooting by looking for broken wires at butt splices with open insulators.
