General Or Light Cleaning
To clean Sunbrella while still on a boat, follow these simple steps:
Brush off loose dirt.
Hose down.
Prepare a cleaning solution of water and mild soap such as Woolite or Dawn dishwashing liquid.
Use a soft bristle brush to clean.
Allow cleaning solution to soak into the fabric.
Rinse thoroughly until all soap residue is removed.
Air dry.
May not require re-treatment depending on the age of the fabric.
If stubborn stains persist, you can use a diluted bleach/soap mixture for spot cleaning of mildew. For roof run-off or other similar stains a strong degreaser may be required.
See our Stain Chart for specifc recommendations.
Heavy Cleaning For Stubborn Stains And Mildew
Sunbrella fabrics do not promote mildew growth, however, mildew may grow on dirt and other foreign substances that are not removed from the fabric. To clean stubborn stains:
Prepare a solution of 1 cup of bleach and one fourth cup mild soap per gallon of clean water.
Allow mixture to soak into fabric for up to 15 minutes.
Blot stain with a sponge or clean towel.
Note: This step should be avoided when cleaning the coated side (Back side) of Sunbrella Plus, Supreme, or Clarity.
Air dry.
