Hi, All.
This week I decided to explore the maintenance readiness of the seawater pump on my newly-acquired 2012 R-29s Yanmar 6BY2-260 engine. Engine coolant temperatures have been entirely normal on trips since we acquired the boat in November, but I have no information whether the original owner ever replaced the impeller, or how long it's been since the last replacement, so investigation was in order.
With my trusty assistant/chief engineer at wrench, we found that the factory-original pump was dripping from the front housing, indicating a failed mechanical seal. After much grunting and foul language from the chief engineer, the pump was out and on the bench for closer inspection to find that the impeller in all likelihood had never before been removed, and that the mechanical seal likely had failed a few hundred hours ago.
My initial inclination was to obtain an OEM replacement pump for installation, and to rebuild the failed pump for a spare when the new pump inevitably fails on a trip. But after watching the extreme discomfort of the chief engineer as he worked that pump off the engine, it became obvious to me that a combination of my size 2XL hands, the protective coating on my rock-hard abs, and my general distaste for working with my head lower than my ankles would combine to make it utterly impractical for me to ever plan to replace that pump at sea by myself.
That sobering reality brought me to where I am now, planning to engineer a redundant backup seawater pump into my engine's cooling system so that when the mechanical pump next fails, I can simply flip a valve and switch and have an electrical pump delivering seawater to my engine's cooling system until I'm safely back at the dock where chief engineer can repair the failed mechanical pump without the threat of emergency, and I can enjoy a cold beer while he works.
My current plan is to plumb ball valves and a tee into the seawater piping to connect a 12v washdown pump with quick connect hardware, and wire the pump so that it runs from a manual switch powered from a relay connected to the oil pressure switch, so that it can only operate while the engine is running (and perhaps with a manual override so that it can run even if the engine has ceased making oil pressure in an extreme emergency). That way I can have instant backup seawater cooling at all times if the main pump fails, and minimize the risk of a temperature-induced propulsion emergency. The cost of keeping spare electric washdown pumps is a tiny fraction of a spare Yanmar seawater pump for these BY-series engines, and if I'm feeling extra paranoid about loss of seawater cooling, I can always hook up two or three spare electric pumps in a standby array. :geek:
So, my question to the group is: have any of you done this sort of custom mod on your own boats? If so, I'd love to hear your thoughts and strategies. Or, have you thought about doing this mod and changed your mind, and if so then why?
