krispirae":2f70uncz said:
Hello! We have a 2008 ranger 25 and our bottom cleaning guy has recommended that the cutlass shaft be replaced, he says he has a friend who can replace it. Is this something he would be able to see? What happens when a cutlass shaft is not replaced? Thank you
Hello Kris,
Firstly, WELCOME to Tugnuts...I agree with Irish Mist.
Secondly, I've heard of a cutlass bearing but never a 'cutlass shaft.' Sorry to nitpick, but when it comes to maintenance, misunderstandings can be costly. There is the
propeller shaft which runs from the transmission...THROUGH the cutlass bearing...and terminates at the propeller.
Are you noticing vibration in the running gear whilst underway?
How many hours are on your boat?
Has the propeller been damaged in the past (thereby possibly damaging the cutlass bearing, bending the prop shaft, etc)?
While changing the cutlass bearing is "simple" conceptually, it does involve
-pulling the boat out of the water, and
-removing the propeller shaft.
You might as well have the stuffing box repacked while you are about it.
Add$ up....
Let us know how it ends up,
dave
