Cutwater 28 Aft Deck Rain Draniage.
bchristie
R-21
Spirit
My 2014 C 28 has two thru-hull fittings on the transom, just below the swim step, to drain rain and other water from the aft deck area. These fittings have flexible flappers to prevent inflow of seawater. The flappers stick in the closed position greatly restricting deck water from draining out. Any suggestions as to how to deal with this?
I had the same problem. They seem to harden up over time. I just did a quick fix and used a hacksaw blade and removed some material at the hinge point. It's on my list to design a 3D printable flapper with an actual hinge. The only problem is my quick fix keeps working and the flapper hasn't broken off yet.
This is a fantastic idea. I’ve been meaning to order a backup and tiny screw to have as a backup, but just printing one would be so much easier.
