Dritchie
- May 19, 2019
- R-23 (Sterndrive)
- Endless Safari
My boat is a 2015 Cutwater 30, hull number FMLC3015j415. The Fusion media player, MS-IP700i has failed and is being replaced, I am told, with the equivalent “current” unit, MS-UD/AV750. The old 700i was connected to a remote-control unit NRX 200i. The unfortunate fact is that the new unit , UD/AV750, is not a 100% plug and play replacement for the old unit, as Fusion has changed from a 8 wire NEMA cable to a 5 wire NEMA cable connection with the new unit. The installed remote-control unit, NRX 200i requires an 8-wire connection.
Do you have a schematic of the layout of the NEMA cabling circuitry for the Cutwater 30 as I can not find the NEMA tee where the NRX 200i and MS 700i connect? I have located the cable exiting and connecting to the “old” 700i but where does this cable connect to the NEMA circuitry? A schematic with boat locations would be appreciated. Also, any thoughts on how to connect the new 5-wire cable to the old 8-wire system….is there such a connector or tee? And an even more fundamental thought is….is the MS-UD/AV750 unit the proper replacement product?... Thank you.
