A good prop shop should be able to repair it for much less than a new one. $400 vs $2200Dritchie":30hybnfh said:Bent two blades on my prop could you please tell what the replacement prop specifications are....diameter, pitch, shaft diameter and manufacturer...thanks
Dritchie":3mjx7hc6 said:Bent two blades on my prop could you please tell what the replacement prop specifications are....diameter, pitch, shaft diameter and manufacturer...thanks
