As dclagett said your engine should have had a PDI performed at or before delivery. The WOT is recored in this form and sent to Volvo for warranty registration. 100rpm over spec max rpm is acceptable with a light load, 3630 is max power set governor. After you get the boat loaded 3530 to 3550 would be a good max RPM. We have a D3 with a rated max rpm of 4000rpm. When we took delivery the Max rpm was 4150 rpm with a lightly loaded boat and two onboard.I performed the PDI myself because the selling dealer was not equipped to do it. When I went over the completed form with a certified Volvo technician he said Volvo doesn't want to see any more then 4130 rpm. I left it alone with the thought that if we have more passengers and equipment it will load it down more. With the added equipment now ,RIB and motor on the transom 4 people on board the engine turns 4030 wot. I don't run there very often but I always run it up just to make sure the engine is loaded properly. 3350 to 3400 is my high cruise speed 85% of wot. I would rather see 100rpm over Max then 100 rpm under Max.
