trailertrawlerkismet
- Feb 23, 2011
- C-24 C
- (2022) Kismet
About once per year I’d have a problem with my Airmar P79 hull mounted dept sounder loosing the depth display on the Garmin GPS screen......the depth would flash and then nothing. With factory guidance I adjusted settings or added fluid to the transducer cup and all was good for about a year. On the most recent episode I was reading the instruction manual to figure out the proper amount of fluid to add and saw that there is supposed to be an O Ring slid up onto the base of the transducer. When checking mine it had no O Ring and therefore the reason the cup would loose fluid over time and cause the transducer to stop reading depth. The ORing is 60mm or 2.3622 inches in size for the inside dimension (id). I only mention this in the event others have a problem in the future. My guess is that the O Ring feel off at some point during one of my inspections.
Jim F
Jim F
