We just purchased a 29s and the main thru-hull is leaking. It appears that it might be a one piece sea strainer thru-hull combo. Is that the case? It is likely that the sea strainer took a hit and transferred the force to the thru-hull.
Is it indeed a one piece unit? When I pull it out and if I find it is damaged, I want to know that part mfg and part number so i can get a replacement.
Can I get it from you ? Do you stock it?
Thanks in advance.
Eric
Thanks in advance.
Eric
