forfun1960
- Feb 12, 2011
- C-242 C
- Journey II
My R-23 does not have a macerator pump and Ranger tells me it will be pretty hard to install one. So I decided to build one that I could connect to the quick coupler on the outlet of the black water tank. The reason to do this is we do a lot of BoaterHoming when towing and without such a pump we could not use the toilet when we are heading home. With this unit, we can pump out when I get home as I have a sewer connection at home I use to discharge my RV tanks.
Also, we can pump out at RV parks or truck stops that have facilities for black water.
Thought others might find of interest. As you can see pretty simple to build from PVC fittings and a couple of valves. Pump and switch ordered from Amazon. Connecting to my 12-volt batteries in the cockpit. The cost to build was around $130.00.
Works really well, the top hose is freshwater to flush the tank, bottom hose discharges with a short piece of clear hose to see when the tank is clean.
Also could use as a high volume bilge pump if needed too. I have a cap for the quick coupler and a couple of short hoses, one connected to the top hose as suction and one on the bottom hose for the discharge.
Pictures are in my album at: gallery2.php?g2_itemId=76973
