ac holmes":2o49gtsd said:Hi folks,
I conferred with John at the factory today regarding the Scotty downrigger mount the goes into the rod holders. It is as follows in the new Scotty Catalog: No. 1028 6 1/8” x 7 1/8” x 9” x 1 1/2”
The angle of the dangle is 30 degrees on the Ranger EC-21 and John suggested replacing the screws that hold the rod holder in place with through bolts.
IMHO, I would also consider a backing plate and some method of making sure that the flat part of the mount is resting on the gunnel and not just the chrome hub of the rod holder. Plumber's epoxy putty comes to mind, or wooden shims, etc. etc. If the ball gets hung up on the bottom and the cable is not cut or the boat not stopped in time , things can get tore up in a big hurry. Typically, downrigger cable is 150-200# test.
Best,
Andrew Holmes
