Bosn Mate
- Dec 23, 2015
- R-29 S
- FMLT2912I718
- Tingira
I am in the process of winterizing the water heater and following the procedure found on page 8 (6. Maintenance; 6.1 Winter Drain). I opened the air bleeder screw mounted on the mixing valve and then opened the drain valve on the waste water outlet. On the bottom of the waste water outlet there is a red water line that travels towards the bow and then disappears from view.
Just want to confirm that the red water line on the bottom of the waste water outlet drains into the bilge.
Appreciate the help!
