Dripless shaft seal/coupling
H28
R-29 S
Hygge
I have a RT29 on Lake Michigan, so fresh water.
I've got 40 plus years on Lake Michigan, doing the Great Loop next year. I'm a bit concerned about salt water in the bilge so thinking of converting over to a dripless shaft seal/coupling.
this question is for salt water inboard engine tug nuts:
Am I overthinking it ? Should I convert, or is it no big deal to have a bit of salt water in the bilge?
Other advantages that I'm not considering?
Any advice, comments, etc. would be appreciated. Thanks in advance.
Dave
What is your concern about salt water? In general it is no big deal, although some folks will fashion a shield to help keep it from being sprayed around when the shaft spins.
The other issue is whether a dripless would even fit; that varies by model.
If you're otherwise OK with the packing you have, I'd personally just keep it and perhaps convert later if/when there is a need to repack or whatever.
We’re on salt water. Not much of an issue. I flush engine with fresh water after each use and allow some overflow into bilge, along with light spraydown. Pumps take care of it. Shield fashioned from a milk jug or other material helps a lot. CorrosionX on motor mounts, etc. Routine care.
I do the following to keep salt a non-issue inside my engine compartment:
1. Fashioned a piece of plastic sheet to sit over the stuffing box to divert any spray (which I don't get anyway with a properly dripping stuffing box) back down into the bilge.
2. In Spring commissiong, I spray down the whole engine and motor mounts with T-9 Boeshield that keeps everything dry and protected from moisture, salt or fresh.
3. At least 3 times a season I will lightly spray down the engine compartment with fresh water, then flush the bilge with plenty of gallons of fresh water.
So far so good. HTH, Gary
I keep my boat in fresh water but being in Puget Sound I spend probably 80% of my running time in salt. On the C30, the shaft seal / packing is far enough back that it doesn't get too close to the transmission or engine. I don't worry about it much, and there's been very little corrosion or wear.
