effiency running
ftornabe
R-25 (Outboard)
FMLT2535A121
Sea Wolf
How high should the trim be raised to be most fuel efficient? I have 2021 R25 outboard. I often run with trim raised four bars with 22 RPM at 8 or 9mph and 1.6 mpg. Has anyone do different with better fuel efficient?
Engine trim is important, as are trim tabs. On a planing hull, the ideal settings are to trim the engine so it's parallel to the flow of water (while the boat has an uphill angle), trim tabs fully retracted (less drag).
I've found 2-3 bars to be normal as the Ranger Tug hull rise isn't that great. The closer to wide open throttle I get, the more engine trim I usually will need. 4,5,6 bars at WOT is normal.
I've also found, that since these are light boats (synonymous with "Trailerable"), thus, the wind pushes us around. If I point the bow of the boat into 10-15 knots of wind gusts while traveling at 28mph,I will notice this at the fuel dock. I've also found that sometimes the more fuel efficient speed is to go faster, not slower. Gets the boat angle down, which picks the back end of the boat up more, to skim along the water.
This is what the stock R25-OB with the factory 3 blade will do.
If you put on a PowerTech 5 blade prop, same boat, different prop.
I've tried all sorts of engine trim settings on our R-25OB with basically zero effect on fuel efficiency, as far as keeping an eye on the chartplotter value (the Yamaha screen's fuel economy tolerance is too large to see anything).
Sometimes I'll trim up to 2-3 bars just in case it actually does make a difference, but any higher than that, I tend to start hearing too many concerning engine noises with any kind of sea state or maneuvers.
We also now have Seakeeper Ride trim tabs, which some people claim to help with fuel efficiency. But again, if there is any difference, it's completely trivial as far as my observations go.
We've always seen about 1.9mpg cruising between 25 and 30 mph, depending on sea state. I figure I can't really complain with that...
I'm primarily running in the Pacific Ocean where it's never calm and subject to frequent wind and current changes. Thankfully, our boats give readouts for speed and gallons per hour, so you can easily see what even a small change will make to fuel efficiency.
I may want to trim up three bars, but if I'm heading into 6 ft. waves directly, with a south and west wind, that may be a bad choice for how the boat rides. So for these conditions, what works best for me is not an automated system, but keeping a constant eye on the gauges and making changes that match the conditions that I'm experiencing.
I'm adjusting both tilt trim and trim tabs in the process to maximize fuel efficiency.
Thanks for the comeback! I try different trim positions and different speeds and see what works best. Sometimes when there's a slight chop the boat rides real smooth and efficient.
Thank you again for replying.
