BobBob
- Jul 13, 2019
- C-302 C
- Red Rover, Red Rover
Here is the informative reply from the ProMariner technical support reply to my question about how to disable the inverter when disconnected from shore power.
Mr. Bonnett,
How is the AC shore power wired into your boat? Does the AC shore come into the Combi and then out to the AC circuit breaker panel? It the AC goes into the Combi first, then the only way to keep the combi from coming on when shore power is lost would be to disconnect the combi batteries. Either remove the in-line fuses or disconnect the wires ar the batteries. Of course, the combi would not be able to charger the batteries when you did have shore power.
If the AC shore power is wired directly to the boat breaker panel and then to the combi you would just have to turn the combi rocker switch to "off".
Regards,
Bruce Giard
Direct: 603-766-7603
Technical Support: 1-800-824-0524
I will check how my boat is wired.
Bob
Mr. Bonnett,
Regards,
Bruce Giard
Bob
