rackline
- Oct 30, 2016
- C-288 C
- FMLT1912K809
- Non-Fluid Motion Model
- 17' Finestkind, previous 35' Friendship Sloop
- Headway
Let me start with apologies for so many questions in this single post. This is our first season since acquiring our 2009 29'. We've had various electrical issues and I wonder if they are related. Most recently, it seems at the same time the generic "check engine" alarm came on, we lost our GPS signal and power to the head. Cleaned the battery cable connections - no joy. No power to the head is a bigger deal than lack of a gps. We're okay using the iPad and charts, but having to use a bucket will keep the admiral off the boat.
Unfortunately, no wires are labeled and few of the many fuse box covers are labeled. Little in the R29 Manual and wiring schematics matches our boat. More to the point, I don't find the head wiring in any of the schematics. Does anyone know where the fuse or a breaker for the Tecma head is located?
Suggestions on resolution to the check engine alarm? Note that the check engine alarm displays and sounds before starting the engine, much like the oil pressure alarm. Once the engine has started the check engine alarm and display has generally been intermittent but has been periodically constant. The Yanmar panel is running version 3 and I read in another post that upgrading to version 4 will display codes. That's probably my first step to troubleshoot, but feedback is welcomed.
GPS signal loss troubleshooting? Everything else on the Garmin 5215 seems to be working correctly.
A few other comments and considerations:
Battery health is good. Engine and thruster batteries were new this spring.
Yanmar engine display does not show accurate fuel level - the Garmin does.
Electric compass seems to be working because heading of boat is correct even though it shows the boat at the wrong location. However, the autopilot displays searching for autopilot controller when running, but the electric compass will display once the engine is shut down.
Prior to these recent issues the check engine alarm would sound if the thrusters were used for more than a few seconds. Shutting off engine and restarting and the alarm would stop. Why would a drain on the thruster battery affect engine voltage (assuming the check engine alarm is low voltage related). And, if it is low voltage, why wouldn't the detailed Yanmar alarm screen display low voltage instead of the generic check engine alert?
Thanks for reading through my laundry list! Even bigger thanks if you have suggestions and resolutions to these issues.
Chris
Chris
