davidr
- Jun 1, 2017
- C-24 C
- Non-Fluid Motion Model
- Cutwater cb30
Having annual engine service on my Cb30 with 435 hp engine. Mechanics noted corrosion on transmission cooler and heat exchanger likely from shaft packing leakage/spray. Have others seen this issue? Am wondering if this is a warranty repair. Other Cutwater owners seem to have similar problems with bearing leakage. Is it a poor quality packing issue? Seems it leaks a lot spraying water around or if tightened sufficiently no drips occur..which is not a good thing.
